HI
Now the company's fader project uses lcp824 chips. NXP's touch solution is used on touch pads. I ported the touch library to the LPC824 life development board. The question now is that you can't identify which pads triggers, I can't find the reason.
The attachment is my hardware connection and code changes.
Besides. I'd like to ask the NXP engineer, can you provide me with a copy of the touch solution source code? Now there are only. lib and. a files, and you don't understand the principles. Thank you!
Hi Rex Lam,
There's the AN11620: LPC82x Touch Solution Application Note and its sample code, please refer to them for details.
TIC
HI jeremyzhou
I've read about lpc82x touch solution's doc, including AN11620: LPC82x Touch Solution Application Note.
but it doesn't solve the problem. I don't know if you can provide the source code for touch solution. thank you!
best regards
xc.mo
I had already attached the source code of AN11620 in previous reply, please check it.
TIC
Hi jerrmyzhou
I said the source code for LPC82x_Touch_lib_v0100.lib, not the example of touch solution. My project was modified according to AN11620_source_code_0.zip. thank you!
You need to sign an NDA with NXP for requesting the code of touch library.
Please contact online business service to learn the details via the https://www.nxp.com/support/support:SUPPORTHOME
TIC
