HI
Now the company's fader project uses lcp824 chips. NXP's touch solution is used on touch pads. I ported the touch library to the LPC824 life development board. The question now is that you can't identify which pads triggers, I can't find the reason.
The attachment is my hardware connection and code changes.
Besides. I'd like to ask the NXP engineer, can you provide me with a copy of the touch solution source code? Now there are only. lib and. a files, and you don't understand the principles. Thank you!
Hi Rex Lam,
There's the AN11620: LPC82x Touch Solution Application Note and its sample code, please refer to them for details.
TIC
HI jeremyzhou
I've read about lpc82x touch solution's doc, including AN11620: LPC82x Touch Solution Application Note.
but it doesn't solve the problem. I don't know if you can provide the source code for touch solution. thank you!
best regards
xc.mo
I had already attached the source code of AN11620 in previous reply, please check it.
TIC
You need to sign an NDA with NXP for requesting the code of touch library.
Please contact online business service to learn the details via the https://www.nxp.com/support/support:SUPPORTHOME
TIC
