LPC810 System Initialization and Configuration
lpcware
Content originally posted in LPCWare by gopi_rm on Thu Jan 02 08:37:07 MST 2014
Hi, I'm new to LPC810 microcontroller. I want to use this uC for a GPS project.
Below are the resources I want to use:
1. Internal clock source
2. 1 UART receiver
3. 1 UART transmitter
4. 4 8-bit registers to be configured as FIFO
What are the SFRs I need to configure to use the above resources?
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri Jan 03 02:17:30 MST 2014
I suggest that you start off by looking at LPCOpen…
http://www.lpcware.com/lpcopen
The LPC8xx family version can then be found at:
http://www.lpcware.com/content/nxpfile/lpcopen-software-development-platform-lpc8xx-packages
LPCXpresso Support
