According to the UM11065 on page 25 of 355, the command handler should answer OK after receiving the raw data of the "Write to RAM" command. However, based on my tests, it does not answer instead.
Can you please confirm it?
I can perform all the other UART commands successfully.
Thanks in advance!
已解决! 转到解答。
Hi Alice,
Thank you very much for your help.
I wasn't aware about AN13815. It is correct then to not have the "OK<CR><LF>" acknowledge from the device after the data is sent.
Luca Zanuttini
Hello @lucazanuttini
It seems the same question with your private ticket, I have reply you on that case.
You can contact me if still have issue on that ticket.
Alice
Hi Alice,
Luca Zanuttini
