LPC55xx ITM global timestamp
2,026件の閲覧回数
Bacterius
I am working on enabling ITM features on an LPC55xx (LPC5504). It works but I have a problem with global timestamps. I am receiving global timestamp packets sent by the device (GTS1/GTS2) but they always have zero payload. Local timestamps are okay so I don't think it is an ITM/DWT configuration problem.
Does LPC55xx support global timestamps in tracing? If so, how are they enabled?
2 返答(返信)
2,023件の閲覧回数
danielholala
Senior Contributor II
I'm wondering what exactly do you mean with "ITM features"?
I only know how to output text to SWO ITM console of MCUXpresso IDE, as described here:
https://www.nxp.com/docs/en/quick-reference-guide/MCUXpresso_IDE_SWO_Trace.pdf
2,020件の閲覧回数
Bacterius
It might be more the DWT but it allows to output things like PC sampling, exception entry/exit, local/global timestamps over the SWO pin. For example https://interrupt.memfault.com/blog/profiling-firmware-on-cortex-m
