LPC55S69JBD100 PUF Demo
joglekaromkar
I am new to the NXP and LPC micro-controllers and i am trying to built the demo for a project.
https://www.nxp.com/docs/en/application-note/AN12324.pdf
and
https://www.nxp.com/docs/en/application-note-software/AN12324SW.zip
I am building it on the following board https://www.okdo.com/de/p/okdo-e1-entwicklungsplatine/ which is based on the LPC55S69JBD100
What are the changes that i have to make on the above board to run the demo successfully ?
joglekaromkar
For anyone facing the above issue. I figured out the solution by replacing the fsl_iap.c file as suggested in this post https://community.nxp.com/t5/MCUXpresso-SDK/SDK-2-7-0-LPCXpresso55S69-zip-flashiap-driver-example-op...
joglekaromkar
