LPC55S69 Secondary Bootloader Reinvoke
henninjw1
I am running through the example in app note AN12327 using an LPC55S69-EVK.  I am able to flash the bootloader and then run the flash_program.bat tool the load the dsbl_app program.  The issue I am running into is trying to re-enter the bootloader from the app using the sbl_api as described on page 12 of the app note.  When I uncomment the sbl_api->reinvoke(); command in the app I get a hard fault failure. I am using the MCUXpresso example code in the app note.
Thanks.
RaRo
Hi  @henninjw1
I hope you're doing well.
Could you tell us the revision and date code of your chip?
Here is an example of where to find those in your chip.
Raul
brianhgw
I have the same issue by using LPC55S69-EVK.
Would you please share us how to solve it?
