LPC55S69 : ICB-AES usage
3,438 次查看
EugeneHiihtaja
Senior Contributor I
Hello !
From hashcrypt SDk example it is quite clear how to use it in ECB and other modes.
But do you have ICB mode usage example what is explained in UM:
48.11.7 Using Indexed Code Book AES (ICB-AES) engine
Specially when key should be loaded from PUF ?
Eugene
4 回复数
3,321 次查看
xiangjun_rong
Hi, Eugene,
As you know that currently we have implemented ECB, CBC and CTR mode of AES algorithms in SDK package based on LPC55S6x, regarding the ICB-AES mode, I have searched in our internal data base, we have neither the code nor the further documentation for the mode.
I am sorry for not helping you.
XiangJun Rong
3,321 次查看
EugeneHiihtaja
Hi xiangjun.rong‌ !
Can you ask examples from headquarter . HW is validated somehow for sure and some examples should be available.
Block is public in UM and should be supported by SW somehow.
Eugene
3,321 次查看
xiangjun_rong
Hi, Eugene,
Unfortunately, we have not the plan to develop the code for the ICB-AES mode till now.
XiangJun Rong
3,275 次查看
cp1
I've also tried setting up ICB-AES, but have run into various problems despite having normal AES ECB working fine.  Would be great to see some proof of concept by NXP!
