LPC55S69 : ARM errata 838869
EugeneHiihtaja
Senior Contributor I
Hello !
I can see interrupt handler in SDk still have errata fix like this :
/* Add for ARM errata 838869, affects Cortex-M4, Cortex-M4F Store immediate overlapping
exception return operation might vector to incorrect interrupt */
#if defined __CORTEX_M && (__CORTEX_M == 4U)
__DSB();
#endif
Does it applicable to this type of MCU or it is Cortex4 only ?
As usually it is under ifdef flag, sometimes without.
Eugene
ZhangJennie
hi Eugene Hiihtaja
Please let me know which SDK demo and which file you are referring to. I will check.
Jun Zhang
EugeneHiihtaja
Hi !
In latest LPC55S69 SDK:
does drivers are common for a lot of MCU/Platforms ?
Eugene
ZhangJennie
Yes, correct.
