LPC55S28 How to determine whether the USB wired has DP and DM
JJ3
Now when I am developing the LPC55S28, I need to determine whether the USB wired has DP or DM. The current method is to judge the reset signal below the PC, but this method is not suitable for my project at present. I want to determine by directly detecting the change of the pin level of DP or DM. Or can it be determined by reading the MCU related registers?
Labels (2)
Hello @JJ3
Do you mean detecting the signal change on pin DP/DM? How about directly measure the pins?
Alice
