LPC5536JBD100 Silicon 0A
mf89
Hi.
We just saw a message in pin_mux.c
    /* Note: PIO0_31 I3C0_SCL only works on A1 chip. */
    IOCON->PIO[0][31] = ((IOCON->PIO[0][31] &
                          /* Mask bits to zero which are setting */
                          (~(IOCON_PIO_FUNC_MASK | IOCON_PIO_DIGIMODE_MASK | IOCON_PIO_OD_MASK)))
                         /* Signal(function) select: PORT031 (pin 23) is configured as I3C0_SCL. */
                         | IOCON_PIO_FUNC(0x0Fu)
                         /* Select Digital mode: Enable Digital mode.
                          * Digital input is enabled. */
                         | IOCON_PIO_DIGIMODE(PIO0_31_DIGIMODE_DIGITAL)
                         /* Controls open-drain mode: Open-drain.
                          * Simulated open-drain output (high drive disabled). */
                         | IOCON_PIO_OD(PIO0_31_OD_OPEN_DRAIN));
It says PIO0_31 I3C0_SCL only works on A1 chip. Is this true ?? If yes how is that not documented anywhere clearly ?
We just have a whole Prototype Series of PCBs that go to the trash if this is correct.
This should be marked in RED color and Double the Font Size in the Datasheet.
danielholala
Senior Contributor II
I agree. Errata like this should be more clearly marked and not hidden in a footnote. Marked in red color and bold print would do.
Harry_Zhang
Hi @mf89
Yes, this is explained in the comments.
Thanks for your understanding.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2132782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC5536JBD100%20Silicon%200A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2132782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi.%3C%2FP%3E%3CP%3EWe%20just%20saw%20a%20message%20in%20pin_mux.c%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%20%20%20%20%2F*%20Note%3A%20PIO0_31%20I3C0_SCL%20only%20works%20on%20A1%20chip.%20*%2F%0A%20%20%20%20IOCON-%26gt%3BPIO%5B0%5D%5B31%5D%20%3D%20((IOCON-%26gt%3BPIO%5B0%5D%5B31%5D%20%26amp%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Mask%20bits%20to%20zero%20which%20are%20setting%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20(~(IOCON_PIO_FUNC_MASK%20%7C%20IOCON_PIO_DIGIMODE_MASK%20%7C%20IOCON_PIO_OD_MASK)))%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Signal(function)%20select%3A%20PORT031%20(pin%2023)%20is%20configured%20as%20I3C0_SCL.%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7C%20IOCON_PIO_FUNC(0x0Fu)%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Select%20Digital%20mode%3A%20Enable%20Digital%20mode.%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*%20Digital%20input%20is%20enabled.%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7C%20IOCON_PIO_DIGIMODE(PIO0_31_DIGIMODE_DIGITAL)%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Controls%20open-drain%20mode%3A%20Open-drain.%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*%20Simulated%20open-drain%20output%20(high%20drive%20disabled).%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7C%20IOCON_PIO_OD(PIO0_31_OD_OPEN_DRAIN))%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EIt%20says%20PIO0_31%20I3C0_SCL%20only%20works%20on%20A1%20chip.%20Is%20this%20true%20%3F%3F%20If%20yes%20how%20is%20that%20not%20documented%20anywhere%20clearly%20%3F%3CBR%20%2F%3E%3CBR%20%2F%3EWe%20just%20have%20a%20whole%20Prototype%20Series%20of%20PCBs%20that%20go%20to%20the%20trash%20if%20this%20is%20correct.%3CBR%20%2F%3E%3CBR%20%2F%3EThis%20should%20be%20marked%20in%20RED%20color%20and%20Double%20the%20Font%20Size%20in%20the%20Datasheet.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC5536JBD100%20Silicon%200A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20agree.%20Errata%20like%20this%20should%20be%20more%20clearly%20marked%20and%20not%20hidden%20in%20a%20footnote.%20Marked%20in%20red%20color%20and%20bold%20print%20would%20do.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC5536JBD100%20Silicon%200A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246985%22%20target%3D%22_blank%22%3E%40mf89%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYes%2C%20this%20is%20explained%20in%20the%20comments.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1752478709050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1752478709050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F347368i2AC164282CE2FBBA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1752478709050.png%22%20alt%3D%22Harry_Zhang_0-1752478709050.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20understanding.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E
