LPC5536 CAN ID Filter
alvarolopes
I am creating a project with LP5536 that I need to use 6 ID Filters, but I am facing some problems. I started using SDK example that have only ID Filter. When I tried to use 6 ID Filters the code generated an error during the CAN initialization:
"MCAN Message RAM configuration failed, please check parameters!"
Follow my code and definitions:
#define TX_BUFFER_OFS 0x20U
#define MSG_RAM_SIZE (TX_BUFFER_OFS + 8 + CAN_DATASIZE)
#define CAN_DATASIZE (64U)
mcan_config_t mcanConfig;
mcan_memory_config_t memoryConfig = {0};
mcan_frame_filter_config_t rxFilter = {0};
mcan_std_filter_element_config_t stdFilter = {0};
mcan_rx_fifo_config_t rxFifo0 = {0};
mcan_tx_buffer_config_t txBuffer = {0};
CLOCK_SetClkDiv(kCLOCK_DivCanClk, 5U, true);
CLOCK_AttachClk(kMCAN_DIV_to_MCAN);
MCAN_GetDefaultConfig(&mcanConfig);
mcan_timing_config_t timing_config;
memset(&timing_config, 0, sizeof(timing_config));
if (MCAN_CalculateImprovedTimingValues(mcanConfig.baudRateA, MCAN_CLK_FREQ, &timing_config))
/* Update the improved timing configuration*/
memcpy(&(mcanConfig.timingConfig), &timing_config, sizeof(mcan_timing_config_t));
else
PRINTF("No found Improved Timing Configuration. use default configuration\r\n\r\n");
mcanConfig.baudRateA = CAN1_SPEED_100kBit;
MCAN_Init(EXAMPLE_MCAN, &mcanConfig, MCAN_CLK_FREQ);
memoryConfig.baseAddr = (uint32_t)msgRam;
/* STD filter config. */
rxFilter.address = STD_FILTER_OFS;
rxFilter.idFormat = kMCAN_FrameIDStandard;
rxFilter.listSize = 6U;
rxFilter.nmFrame = kMCAN_reject0;
rxFilter.remFrame = kMCAN_rejectFrame;
memoryConfig.stdFilterCfg = &rxFilter;
/* RX fifo0 config. */
rxFifo0.address = RX_FIFO0_OFS;
rxFifo0.elementSize = 1U;
rxFifo0.watermark = 0;
rxFifo0.opmode = kMCAN_FifoBlocking;
//rxFifo0.datafieldSize = kMCAN_8ByteDatafield;
rxFifo0.datafieldSize = kMCAN_64ByteDatafield;
memoryConfig.rxFifo0Cfg = &rxFifo0;
/* TX buffer config. */
txBuffer.address = TX_BUFFER_OFS;
txBuffer.dedicatedSize = 1U;
txBuffer.fqSize = 0;
txBuffer.datafieldSize = kMCAN_8ByteDatafield;
memoryConfig.txBufferCfg = &txBuffer;
/* Set Message RAM config and clear memory to avoid BEU/BEC error. */
memset((void *)msgRam, 0, MSG_RAM_SIZE * sizeof(uint8_t));
if (kStatus_Success != MCAN_SetMessageRamConfig(EXAMPLE_MCAN, &memoryConfig))
PRINTF("MCAN Message RAM configuration failed, please check parameters!\r\n");
return -1;
 If anyone has a tip to help me, I would appreciate.
Regards!
carlos_o
Hi @alvarolopes
Thanks for your post
Could you please share which version of MCUXpresso and the SDK are you using?
You mentioned that the issue happens at the can initialization, but error log you share is from "
return -1;
Please debug the MCAN_SetMessageRamConfig function and share where the code is going to kStatus_Fail
alvarolopes
MCUXpresso version:
MCUXpresso IDE v25.6
The problem happens when I use more than 4 ID filters (rxFilter.listSize).
Follow my entire code:
    /* Initialize board hardware. */
    //BOARD_InitHardware();
    //Set MCAN clock 100Mhz/5=20MHz.
    PRINTF("\r\n==MCAN loopback functional example -- Start.==\r\n\r\n");
    /* Get MCAN module default Configuration. */
     * mcanConfig.baudRate               = 500000U;
     * mcanConfig.baudRateFD             = 2000000U;
     * mcanConfig.enableCanfdNormal      = false;
     * mcanConfig.enableCanfdSwitch      = false;
     * mcanConfig.enableLoopBackInt      = false;
     * mcanConfig.enableLoopBackExt      = false;
     * mcanConfig.enableBusMon           = false;
    /* Enable external loop back mode.
     * Current node treats its own transmitted messages as received messages,
     * Other node can receive Current node transmitted messages,
     * Other node can't transmit messages or ACK signal to Current node.
    //mcanConfig.enableLoopBackExt = true;
    else
Follow is when the error occurs
        return -1;
If you put     "rxFilter.listSize > 4" , the message "MCAN Message RAM configuration failed, please check parameters!" will be displayed.
And follow my filters:
stdFilter.sfec = kMCAN_storeinFifo0;
//Classic filter mode, only filter matching ID.
stdFilter.sft   = kMCAN_classic;
stdFilter.sfid1 = 0x4B0U;
stdFilter.sfid2 = 0x7FFU;
MCAN_SetSTDFilterElement(EXAMPLE_MCAN, &rxFilter, &stdFilter, 0);
stdFilter.sfid1 = 0x600U;
MCAN_SetSTDFilterElement(EXAMPLE_MCAN, &rxFilter, &stdFilter, 1);
stdFilter.sfid1 = 0x1a1U;
MCAN_SetSTDFilterElement(EXAMPLE_MCAN, &rxFilter, &stdFilter, 2);
stdFilter.sfid1 = 0x2a2U;
MCAN_SetSTDFilterElement(EXAMPLE_MCAN, &rxFilter, &stdFilter, 3);
stdFilter.sfid1 = 0x421U;
MCAN_SetSTDFilterElement(EXAMPLE_MCAN, &rxFilter, &stdFilter, 4);
stdFilter.sfid1 = 0x100U;
MCAN_SetSTDFilterElement(EXAMPLE_MCAN, &rxFilter, &stdFilter, 5);
    /* Enable RX fifo0 new message interrupt using interrupt line 0. */
    MCAN_EnableInterrupts(EXAMPLE_MCAN, 0, CAN_IE_RF0NE_MASK);
    EnableIRQ(CAN0_IRQ0_IRQn);
Alvaro
carlos_o
Hi @alvarolopes
The MCAN_SetMessageRamConfig function fail due to wrong address parameter, this is related to memoryConfig configuration.
Please make sure msgRam has 4k alignment.
Also share the value of MSG_RAM_SIZE
alvarolopes
#define MSG_RAM_BASE 0x04000000U
How can I know if my RAM has 4k alignment?
Alvaro
carlos_o
Hi @alvarolopes
Apologies the late reply
I do some test at my end and I've found the following:
To have more than 4 filters you need to modify the rxFifo0.address value to be at least 4 * rxFilter.listsize so you need rxFifo0.address be equal to 0x18 at minimum to support 6 filters.
Regarding the alignment question to ensure the start of msg_ram to be align you only need to ensure that the value of MSG_RAM_BASE is divisible per 0x1000, the value you assign is aligned.
Let me know if this information solves the issue.
alvarolopes
Hello my friend. Excuse me for delay.
Good news. It works, but I needed to change the register txBuffer.address to
0x28.
The final configuration was:
RX_FIFO0_OFS = 0x18
TX_BUFFER_OFS = 0x28
Alvaro
carlos_o
Hi @alvarolopes
Great to hear that!
Thanks for letting me know and share the configurations that works for you.
%3CLINGO-SUB%20id%3D%22lingo-sub-2305496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC5536%20CAN%20ID%20Filter%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20creating%20a%20project%20with%20LP5536%20that%20I%20need%20to%20use%206%20ID%20Filters%2C%20but%20I%20am%20facing%20some%20problems.%20I%20started%20using%20SDK%20example%20that%20have%20only%20ID%20Filter.%20When%20I%20tried%20to%20use%206%20ID%20Filters%20the%20code%20generated%20an%20error%20during%20the%20CAN%20initialization%3A%3C%2FP%3E%3CP%3E%3CSPAN%3E%22MCAN%20Message%20RAM%20configuration%20failed%2C%20please%20check%20parameters!%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EFollow%20my%20code%20and%20definitions%3A%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20TX_BUFFER_OFS%200x20U%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20MSG_RAM_SIZE%20(TX_BUFFER_OFS%20%2B%208%20%2B%20CAN_DATASIZE)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3ECAN_DATASIZE%3C%2FSPAN%3E%3CSPAN%3E%20(64U)%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Emcan_config_t%3C%2FSPAN%3E%3CSPAN%3E%20mcanConfig%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emcan_memory_config_t%3C%2FSPAN%3E%3CSPAN%3E%20memoryConfig%20%3D%20%7B0%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emcan_frame_filter_config_t%3C%2FSPAN%3E%3CSPAN%3E%20rxFilter%20%3D%20%7B0%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emcan_std_filter_element_config_t%3C%2FSPAN%3E%3CSPAN%3E%20stdFilter%20%3D%20%7B0%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Emcan_rx_fifo_config_t%3C%2FSPAN%3E%3CSPAN%3E%20rxFifo0%20%3D%20%7B0%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emcan_tx_buffer_config_t%3C%2FSPAN%3E%3CSPAN%3E%20txBuffer%20%3D%20%7B0%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3ECLOCK_SetClkDiv(%3C%2FSPAN%3E%3CSPAN%3EkCLOCK_DivCanClk%3C%2FSPAN%3E%3CSPAN%3E%2C%205U%2C%20true)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECLOCK_AttachClk(%3C%2FSPAN%3E%3CSPAN%3EkMCAN_DIV_to_MCAN%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3EMCAN_GetDefaultConfig(%26amp%3BmcanConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Emcan_timing_config_t%3C%2FSPAN%3E%3CSPAN%3E%20timing_config%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ememset(%26amp%3Btiming_config%2C%200%2C%20%3C%2FSPAN%3E%3CSPAN%3Esizeof%3C%2FSPAN%3E%3CSPAN%3E(timing_config))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%20(MCAN_CalculateImprovedTimingValues(mcanConfig.%3C%2FSPAN%3E%3CSPAN%3EbaudRateA%3C%2FSPAN%3E%3CSPAN%3E%2C%20MCAN_CLK_FREQ%2C%20%26amp%3Btiming_config))%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Update%20the%20improved%20timing%20configuration*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ememcpy(%26amp%3B(mcanConfig.%3C%2FSPAN%3E%3CSPAN%3EtimingConfig%3C%2FSPAN%3E%3CSPAN%3E)%2C%20%26amp%3Btiming_config%2C%20%3C%2FSPAN%3E%3CSPAN%3Esizeof%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Emcan_timing_config_t%3C%2FSPAN%3E%3CSPAN%3E))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPRINTF(%3C%2FSPAN%3E%3CSPAN%3E%22No%20found%20Improved%20Timing%20Configuration.%20use%20default%20configuration%5Cr%5Cn%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3EmcanConfig.%3C%2FSPAN%3E%3CSPAN%3EbaudRateA%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20CAN1_SPEED_100kBit%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EMCAN_Init(EXAMPLE_MCAN%2C%20%26amp%3BmcanConfig%2C%20MCAN_CLK_FREQ)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EmemoryConfig.%3C%2FSPAN%3E%3CSPAN%3EbaseAddr%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20(%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E)msgRam%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20STD%20filter%20%3C%2FSPAN%3E%3CSPAN%3Econfig%3C%2FSPAN%3E%3CSPAN%3E.%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ErxFilter.%3C%2FSPAN%3E%3CSPAN%3Eaddress%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20STD_FILTER_OFS%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ErxFilter.%3C%2FSPAN%3E%3CSPAN%3EidFormat%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkMCAN_FrameIDStandard%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ErxFilter.%3C%2FSPAN%3E%3CSPAN%3ElistSize%3C%2FSPAN%3E%3CSPAN%3E%20%3D%206U%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ErxFilter.%3C%2FSPAN%3E%3CSPAN%3EnmFrame%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkMCAN_reject0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ErxFilter.%3C%2FSPAN%3E%3CSPAN%3EremFrame%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkMCAN_rejectFrame%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EmemoryConfig.%3C%2FSPAN%3E%3CSPAN%3EstdFilterCfg%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%26amp%3BrxFilter%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%2F*%20RX%20fifo0%20%3C%2FSPAN%3E%3CSPAN%3Econfig%3C%2FSPAN%3E%3CSPAN%3E.%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ErxFifo0.%3C%2FSPAN%3E%3CSPAN%3Eaddress%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20RX_FIFO0_OFS%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ErxFifo0.%3C%2FSPAN%3E%3CSPAN%3EelementSize%3C%2FSPAN%3E%3CSPAN%3E%20%3D%201U%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ErxFifo0.%3C%2FSPAN%3E%3CSPAN%3Ewatermark%3C%2FSPAN%3E%3CSPAN%3E%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ErxFifo0.%3C%2FSPAN%3E%3CSPAN%3Eopmode%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkMCAN_FifoBlocking%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2FrxFifo0.datafieldSize%20%3D%20kMCAN_8ByteDatafield%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ErxFifo0.%3C%2FSPAN%3E%3CSPAN%3EdatafieldSize%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkMCAN_64ByteDatafield%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3EmemoryConfig.%3C%2FSPAN%3E%3CSPAN%3ErxFifo0Cfg%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%26amp%3BrxFifo0%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20TX%20buffer%20%3C%2FSPAN%3E%3CSPAN%3Econfig%3C%2FSPAN%3E%3CSPAN%3E.%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EtxBuffer.%3C%2FSPAN%3E%3CSPAN%3Eaddress%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20TX_BUFFER_OFS%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EtxBuffer.%3C%2FSPAN%3E%3CSPAN%3EdedicatedSize%3C%2FSPAN%3E%3CSPAN%3E%20%3D%201U%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EtxBuffer.%3C%2FSPAN%3E%3CSPAN%3EfqSize%3C%2FSPAN%3E%3CSPAN%3E%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EtxBuffer.%3C%2FSPAN%3E%3CSPAN%3EdatafieldSize%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkMCAN_8ByteDatafield%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3EmemoryConfig.%3C%2FSPAN%3E%3CSPAN%3EtxBufferCfg%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20%26amp%3BtxBuffer%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F*%20Set%20Message%20RAM%20%3C%2FSPAN%3E%3CSPAN%3Econfig%3C%2FSPAN%3E%3CSPAN%3E%20and%20clear%20memory%20to%20avoid%20BEU%2FBEC%20error.%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ememset((%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E%20*)msgRam%2C%200%2C%20MSG_RAM_SIZE%20*%20%3C%2FSPAN%3E%3CSPAN%3Esizeof%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3E))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%20(kStatus_Success%20!%3D%20MCAN_SetMessageRamConfig(EXAMPLE_MCAN%2C%20%26amp%3BmemoryConfig))%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPRINTF(%3C%2FSPAN%3E%3CSPAN%3E%22MCAN%20Message%20RAM%20configuration%20failed%2C%20please%20check%20parameters!%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ereturn%3C%2FSPAN%3E%3CSPAN%3E%20-1%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%26nbsp%3BIf%20anyone%20has%20a%20tip%20to%20help%20me%2C%20I%20would%20appreciate.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards!%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2311992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC5536%20CAN%20ID%20Filter%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2311992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EMCUXpresso%20version%3A%3C%2FP%3E%3CP%3E%3CSPAN%3EMCUXpresso%20IDE%20v25.6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThe%20problem%20happens%20when%20I%20use%20more%20than%204%20ID%20filters%20(rxFilter.listSize).%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFollow%20my%20entire%20code%3A%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emcan_config_t%20mcanConfig%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20mcan_memory_config_t%20memoryConfig%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3D%20%7B0%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20mcan_frame_filter_config_t%20rxFilter%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3D%20%7B0%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20mcan_std_filter_element_config_t%20stdFilter%20%3D%20%7B0%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20mcan_rx_fifo_config_t%20rxFifo0%26nbsp%3B%20%26nbsp%3B%20%3D%20%7B0%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20mcan_tx_buffer_config_t%20txBuffer%20%3D%20%7B0%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20Initialize%20board%20hardware.%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F%2FBOARD_InitHardware()%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F%2FSet%20MCAN%20clock%20100Mhz%2F5%3D20MHz.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20CLOCK_SetClkDiv(kCLOCK_DivCanClk%2C%205U%2C%20true)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20CLOCK_AttachClk(kMCAN_DIV_to_MCAN)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20PRINTF(%22%5Cr%5Cn%3D%3DMCAN%20loopback%20functional%20example%20--%20Start.%3D%3D%5Cr%5Cn%5Cr%5Cn%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20Get%20MCAN%20module%20default%20Configuration.%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%20mcanConfig.baudRate%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3D%20500000U%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%20mcanConfig.baudRateFD%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3D%202000000U%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%20mcanConfig.enableCanfdNormal%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3D%20false%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%20mcanConfig.enableCanfdSwitch%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3D%20false%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%20mcanConfig.enableLoopBackInt%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3D%20false%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%20mcanConfig.enableLoopBackExt%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3D%20false%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%20mcanConfig.enableBusMon%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3D%20false%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20MCAN_GetDefaultConfig(%26amp%3BmcanConfig)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20Enable%20external%20loop%20back%20mode.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%20Current%20node%20treats%20its%20own%20transmitted%20messages%20as%20received%20messages%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%20Other%20node%20can%20receive%20Current%20node%20transmitted%20messages%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%20Other%20node%20can't%20transmit%20messages%20or%20ACK%20signal%20to%20Current%20node.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F%2FmcanConfig.enableLoopBackExt%20%3D%20true%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20mcan_timing_config_t%20timing_config%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20memset(%26amp%3Btiming_config%2C%200%2C%20sizeof(timing_config))%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(MCAN_CalculateImprovedTimingValues(mcanConfig.baudRateA%2C%20MCAN_CLK_FREQ%2C%20%26amp%3Btiming_config))%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%2F*%20Update%20the%20improved%20timing%20configuration*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20memcpy(%26amp%3B(mcanConfig.timingConfig)%2C%20%26amp%3Btiming_config%2C%20sizeof(mcan_timing_config_t))%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20else%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20PRINTF(%22No%20found%20Improved%20Timing%20Configuration.%20use%20default%20configuration%5Cr%5Cn%5Cr%5Cn%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EmcanConfig.baudRateA%20%3D%20CAN1_SPEED_100kBit%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20MCAN_Init(EXAMPLE_MCAN%2C%20%26amp%3BmcanConfig%2C%20MCAN_CLK_FREQ)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20memoryConfig.baseAddr%20%3D%20(uint32_t)msgRam%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20STD%20filter%20config.%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20rxFilter.address%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3D%20STD_FILTER_OFS%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20rxFilter.idFormat%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3D%20kMCAN_FrameIDStandard%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20rxFilter.listSize%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3D%206U%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20rxFilter.nmFrame%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3D%20kMCAN_reject0%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20rxFilter.remFrame%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3D%20kMCAN_rejectFrame%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20memoryConfig.stdFilterCfg%20%3D%20%26amp%3BrxFilter%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20RX%20fifo0%20config.%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20rxFifo0.address%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3D%20RX_FIFO0_OFS%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20rxFifo0.elementSize%26nbsp%3B%20%26nbsp%3B%3D%201U%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20rxFifo0.watermark%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3D%200%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20rxFifo0.opmode%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3D%20kMCAN_FifoBlocking%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20rxFifo0.datafieldSize%20%3D%20kMCAN_8ByteDatafield%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20memoryConfig.rxFifo0Cfg%20%3D%20%26amp%3BrxFifo0%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20TX%20buffer%20config.%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20txBuffer.address%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3D%20TX_BUFFER_OFS%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20txBuffer.dedicatedSize%20%3D%201U%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20txBuffer.fqSize%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20txBuffer.datafieldSize%20%3D%20kMCAN_8ByteDatafield%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20memoryConfig.txBufferCfg%20%3D%20%26amp%3BtxBuffer%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp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nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EFollow%20is%20when%20the%20error%20occurs%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20Set%20Message%20RAM%20config%20and%20clear%20memory%20to%20avoid%20BEU%2FBEC%20error.%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20memset((void%20*)msgRam%2C%200%2C%20MSG_RAM_SIZE%20*%20sizeof(uint8_t))%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(kStatus_Success%20!%3D%20MCAN_SetMessageRamConfig(EXAMPLE_MCAN%2C%20%26amp%3BmemoryConfig))%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20PRINTF(%22MCAN%20Message%20RAM%20configuration%20failed%2C%20please%20check%20parameters!%5Cr%5Cn%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20return%20-1%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EIf%20you%20put%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%22rxFilter.listSize%20%26gt%3B%204%22%20%2C%20the%20message%20%22MCAN%20Message%20RAM%20configuration%20failed%2C%20please%20check%20parameters!%22%20will%20be%20displayed.%3C%2FDIV%3E%3CDIV%3E%26nbsp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nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAnd%20follow%20my%20filters%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfec%20%3D%20kMCAN_storeinFifo0%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2FClassic%20filter%20mode%2C%20only%20filter%20matching%20ID.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sft%26nbsp%3B%20%26nbsp%3B%3D%20kMCAN_classic%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid1%20%3D%200x4B0U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid2%20%3D%200x7FFU%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMCAN_SetSTDFilterElement(EXAMPLE_MCAN%2C%20%26amp%3BrxFilter%2C%20%26amp%3BstdFilter%2C%200)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfec%20%3D%20kMCAN_storeinFifo0%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2FClassic%20filter%20mode%2C%20only%20filter%20matching%20ID.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sft%26nbsp%3B%20%26nbsp%3B%3D%20kMCAN_classic%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid1%20%3D%200x600U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid2%20%3D%200x7FFU%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMCAN_SetSTDFilterElement(EXAMPLE_MCAN%2C%20%26amp%3BrxFilter%2C%20%26amp%3BstdFilter%2C%201)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfec%20%3D%20kMCAN_storeinFifo0%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2FClassic%20filter%20mode%2C%20only%20filter%20matching%20ID.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sft%26nbsp%3B%20%26nbsp%3B%3D%20kMCAN_classic%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid1%20%3D%200x1a1U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid2%20%3D%200x7FFU%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMCAN_SetSTDFilterElement(EXAMPLE_MCAN%2C%20%26amp%3BrxFilter%2C%20%26amp%3BstdFilter%2C%202)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfec%20%3D%20kMCAN_storeinFifo0%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2FClassic%20filter%20mode%2C%20only%20filter%20matching%20ID.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sft%26nbsp%3B%20%26nbsp%3B%3D%20kMCAN_classic%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid1%20%3D%200x2a2U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid2%20%3D%200x7FFU%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMCAN_SetSTDFilterElement(EXAMPLE_MCAN%2C%20%26amp%3BrxFilter%2C%20%26amp%3BstdFilter%2C%203)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfec%20%3D%20kMCAN_storeinFifo0%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2FClassic%20filter%20mode%2C%20only%20filter%20matching%20ID.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sft%26nbsp%3B%20%26nbsp%3B%3D%20kMCAN_classic%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid1%20%3D%200x421U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid2%20%3D%200x7FFU%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMCAN_SetSTDFilterElement(EXAMPLE_MCAN%2C%20%26amp%3BrxFilter%2C%20%26amp%3BstdFilter%2C%204)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfec%20%3D%20kMCAN_storeinFifo0%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2FClassic%20filter%20mode%2C%20only%20filter%20matching%20ID.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sft%26nbsp%3B%20%26nbsp%3B%3D%20kMCAN_classic%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid1%20%3D%200x100U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EstdFilter.sfid2%20%3D%200x7FFU%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMCAN_SetSTDFilterElement(EXAMPLE_MCAN%2C%20%26amp%3BrxFilter%2C%20%26amp%3BstdFilter%2C%205)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20Enable%20RX%20fifo0%20new%20message%20interrupt%20using%20interrupt%20line%200.%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20MCAN_EnableInterrupts(EXAMPLE_MCAN%2C%200%2C%20CAN_IE_RF0NE_MASK)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20EnableIRQ(CAN0_IRQ0_IRQn)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ERegards%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EAlvaro%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2311648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC5536%20CAN%20ID%20Filter%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2311648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F67396%22%20target%3D%22_blank%22%3E%40alvarolopes%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20share%20which%20version%20of%20MCUXpresso%20and%20the%20SDK%20are%20you%20using%3F%3C%2FP%3E%0A%3CP%3EYou%20mentioned%20that%20the%20issue%20happens%20at%20the%20can%20initialization%2C%20but%20error%20log%20you%20share%20is%20from%20%22%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B(kStatus_Success%20!%3D%20MCAN_SetMessageRamConfig(EXAMPLE_MCAN%2C%20%26amp%3BmemoryConfig))%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EPRINTF(%3C%2FSPAN%3E%3CSPAN%3E%22MCAN%20Message%20RAM%20configuration%20failed%2C%20please%20check%20parameters!%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Ereturn%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B-1%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%22%3C%2FP%3E%0A%3CP%3EPlease%20debug%20the%26nbsp%3BMCAN_SetMessageRamConfig%20function%20and%20share%20where%20the%20code%20is%20going%20to%26nbsp%3BkStatus_Fail%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC5536%20CAN%20ID%20Filter%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F67396%22%20target%3D%22_blank%22%3E%40alvarolopes%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20MCAN_SetMessageRamConfig%20function%20fail%26nbsp%3Bdue%20to%20wrong%20address%20parameter%2C%20this%20is%20related%20to%26nbsp%3BmemoryConfig%20configuration.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20make%20sure%26nbsp%3BmsgRam%20has%204k%20alignment.%3C%2FP%3E%0A%3CP%3EAlso%20share%20the%20value%20of%26nbsp%3BMSG_RAM_SIZE%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC5536%20CAN%20ID%20Filter%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20MSG_RAM_BASE%200x04000000U%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3ETX_BUFFER_OFS%3C%2FSPAN%3E%3CSPAN%3E%200x20U%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20CAN_DATASIZE%20(64U)%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%3CSPAN%3E%20MSG_RAM_SIZE%20(TX_BUFFER_OFS%20%2B%208%20%2B%20CAN_DATASIZE)%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3EHow%20can%20I%20know%20if%20my%20RAM%20has%204k%20alignment%3F%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EAlvaro%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2316680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC5536%20CAN%20ID%20Filter%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F67396%22%20target%3D%22_blank%22%3E%40alvarolopes%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EApologies%20the%20late%20reply%3C%2FP%3E%0A%3CP%3EI%20do%20some%20test%20at%20my%20end%20and%20I've%20found%20the%20following%3A%3C%2FP%3E%0A%3CP%3ETo%20have%20more%20than%204%20filters%20you%20need%20to%20modify%20the%26nbsp%3BrxFifo0.address%20value%20to%20be%20at%20least%204%20*%20rxFilter.listsize%20so%20you%20need%26nbsp%3BrxFifo0.address%20be%20equal%20to%200x18%20at%20minimum%20to%20support%206%20filters.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ERegarding%20the%20alignment%20question%20to%20ensure%20the%20start%20of%20msg_ram%20to%20be%20align%20you%20only%20need%20to%20ensure%20that%20the%20value%20of%26nbsp%3BMSG_RAM_BASE%20is%26nbsp%3Bdivisible%20per%200x1000%2C%20the%20value%20you%20assign%20is%20aligned.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ELet%20me%20know%20if%20this%20information%20solves%20the%20issue.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2319560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC5536%20CAN%20ID%20Filter%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2319560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EHello%20my%20friend.%20Excuse%20me%20for%20delay.%3C%2FP%3E%3CP%3EGood%20news.%20It%20works%2C%20but%20I%20needed%20to%20change%20the%20register%20txBuffer.address%20to%3C%2FP%3E%3CP%3E0x28.%3C%2FP%3E%3CP%3EThe%20final%20configuration%20was%3A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3ERX_FIFO0_OFS%20%3D%200x18%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3ErxFifo0.%3C%2FSPAN%3E%3CSPAN%3Eaddress%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20RX_FIFO0_OFS%3B%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3ETX_BUFFER_OFS%20%3D%200x28%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EtxBuffer.%3C%2FSPAN%3E%3CSPAN%3Eaddress%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20TX_BUFFER_OFS%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EAlvaro%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2319743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC5536%20CAN%20ID%20Filter%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2319743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F67396%22%20target%3D%22_blank%22%3E%40alvarolopes%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EGreat%20to%20hear%20that!%3C%2FP%3E%0A%3CP%3EThanks%20for%20letting%20me%20know%20and%20share%20the%20configurations%20that%20works%20for%20you.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
