LPC54618J512 GPIO Pin Initial State Issue
nithin3200
Hello everyone,
I have a custom PCB mounted with an LPC54618J512 controller. I have initially configured the GPIO pin (PIO4_16) as a digital output with an initial state set to low. This pin is used to switch an N-channel MOSFET.
During the booting period, the GPIO pin should remain low, but I am observing a 250 ms high pulse before it goes to the low state. I need the GPIO state to remain low throughout the booting period. This issue is not specific to any particular GPIO pin; it occurs across all GPIO pins. I am unsure why I am getting this 250 ms high pulse.
For reference, I am attaching the GPIO configuration screenshot. The yellow pulse represents the GPIO (PIO4_16) signals.
Any suggestions to resolve this issue would be greatly appreciated.
Thank you!
nithin3200
@xiangjun_rong ,
Thanks for your prompt replay. As per your suggestion I connected the 5K ohm pull down resistor. The noise has been removed, and the issue is solved.
Thank you very much for your guidance.
Nithin
xiangjun_rong
As you know that the GPIO pin is in input mode in default after Reset, so the pin is subject to noise.
Pls try to connect a pull-down resistor on the pin and check if the pulse appears or not after reset.
If the pulse still appears after you connect a pull-down resistor, it is a tough issue.
Xiangjun Rong
nithin3200
Hi@ xiangjun_rong
Thanks for the reply. We have already connected the pull-down resistor in the hardware. Are there any other issues we should check?
Nithin
xiangjun_rong
Pls connect a 5K ohm pull-down resistor on the PIO4_16 pin. If you still see the high pulse during the start-up process, at this time, because the software has not begun to be executed, so software can not solve it. For hardware, the pull-down resistor is the only way I suppose.
As I said it is a tough issue.
XiangJun Rong
nithin3200
@xiangjun_rong ,
Nithin
%3CLINGO-SUB%20id%3D%22lingo-sub-1947319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC54618J512%20GPIO%20Pin%20Initial%20State%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1947319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3EHello%20everyone%2C%3C%2FP%3E%3CP%3EI%20have%20a%20custom%20PCB%20mounted%20with%20an%20LPC54618J512%20controller.%20I%20have%20initially%20configured%20the%20GPIO%20pin%20(PIO4_16)%20as%20a%20digital%20output%20with%20an%20initial%20state%20set%20to%20low.%20This%20pin%20is%20used%20to%20switch%20an%20N-channel%20MOSFET.%3C%2FP%3E%3CP%3EDuring%20the%20booting%20period%2C%20the%20GPIO%20pin%20should%20remain%20low%2C%20but%20I%20am%20observing%20a%20250%20ms%20high%20pulse%20before%20it%20goes%20to%20the%20low%20state.%20I%20need%20the%20GPIO%20state%20to%20remain%20low%20throughout%20the%20booting%20period.%20This%20issue%20is%20not%20specific%20to%20any%20particular%20GPIO%20pin%3B%20it%20occurs%20across%20all%20GPIO%20pins.%20I%20am%20unsure%20why%20I%20am%20getting%20this%20250%20ms%20high%20pulse.%3C%2FP%3E%3CP%3EFor%20reference%2C%20I%20am%20attaching%20the%20GPIO%20configuration%20screenshot.%20The%20yellow%20pulse%20represents%20the%20GPIO%20(PIO4_16)%20signals.%3C%2FP%3E%3CP%3EAny%20suggestions%20to%20resolve%20this%20issue%20would%20be%20greatly%20appreciated.%3C%2FP%3E%3CP%3EThank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1953013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC54618J512%20GPIO%20Pin%20Initial%20State%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1953013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F26034%22%20target%3D%22_blank%22%3E%40xiangjun_rong%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThanks%20for%20your%20prompt%20replay.%20As%20per%20your%20suggestion%20I%20connected%20the%205K%20ohm%20pull%20down%20resistor.%20The%20noise%20has%20been%20removed%2C%20and%20the%20issue%20is%20solved.%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20your%20guidance.%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3ENithin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1950469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC54618J512%20GPIO%20Pin%20Initial%20State%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1950469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EPls%20connect%20a%205K%20ohm%20pull-down%20resistor%20on%20the%20PIO4_16%20pin.%20If%20you%20still%20see%20the%20high%20pulse%20during%20the%20start-up%20process%2C%20at%20this%20time%2C%20because%20the%20software%20has%20not%20begun%20to%20be%20executed%2C%20so%20software%20can%20not%20solve%20it.%20For%20hardware%2C%20the%20pull-down%20resistor%20is%20the%20only%20way%20I%20suppose.%3C%2FP%3E%0A%3CP%3EAs%20I%20said%20it%20is%20a%20tough%20issue.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EXiangJun%20Rong%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1948715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC54618J512%20GPIO%20Pin%20Initial%20State%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1948715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EHi%40%20xiangjun_rong%3C%2FP%3E%3CP%3EThanks%20for%20the%20reply.%20We%20have%20already%20connected%20the%20pull-down%20resistor%20in%20the%20hardware.%20Are%20there%20any%20other%20issues%20we%20should%20check%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3ENithin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1947650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC54618J512%20GPIO%20Pin%20Initial%20State%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1947650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EAs%20you%20know%20that%20the%20GPIO%20pin%20is%20in%20input%20mode%20in%20default%20after%20Reset%2C%20so%20the%20pin%20is%20subject%20to%20noise.%3C%2FP%3E%0A%3CP%3EPls%20try%20to%20connect%20a%20pull-down%20resistor%20on%20the%20pin%20and%20check%20if%20the%20pulse%20appears%20or%20not%20after%20reset.%3C%2FP%3E%0A%3CP%3EIf%20the%20pulse%20still%20appears%20after%20you%20connect%20a%20pull-down%20resistor%2C%20it%20is%20a%20tough%20issue.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EXiangjun%20Rong%3C%2FP%3E%3C%2FLINGO-BODY%3E
