LPC54605 ISP UART
LPC54605 ISP UART
2,414 次查看
Mateusz_K
I am using ISP through UART on LPC54605. I follow the procedure described in the User Manual, that is:
- send synchronization char
- send "Synchronized\r\n"
- send freq
After all this commands I am getting expected response. How ever, when I send Unlock command I am receiving ERR_ISP_PARAM_ERROR return code. Unlock commands which I am sending is structured as:
"U 23130\r\n"
Procedure, which I am using works on other LPC devices, such as LPC11Axx.
标签 (2)
3 回复数
2,390 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, is there a possibility that your device is locked, could you try to use the SPSDK and on this use BLHOST to read if the flash is lock.
Installation Guide — SPSDK documentation
Pavel
2,330 次查看
Mateusz_K
I won't install it, but I am sure that device is not locked. ECRP region in flash is empty, I can reprogram and erase the device using SWD
2,325 次查看
Mateusz_K
I mean, I will try to install it, meanwhile: UART communication looks like this
