LPC54102 Supply Current Below 12 MHz
1,251件の閲覧回数
mikenn
Hello
In LPC54102 the data sheets offer supply current specifications for clocks and or above 12 MHz.  Is there any data for lower clock speeds?  I've noticed some LPC11xxx variants offer this specification for clocks at 1 - 6 MHz.
1,120件の閲覧回数
kerryzhou
Hi Mike,
  Unfortunately, now LPC54102 just give the power consumption above 12Mhz, no data for lower clock speeds, if you need it, maybe you need to test it by your own condition.
Kerry
