LPC51u68 lpcxpresso51u68_dev_cdc_vcom_bm
2,223 次查看
filipecostapica
Hello to everyone.
I'm running the SDK example "lpcxpresso51u68_dev_cdc_vcom_bm" on a controller(LPC51U68JBD48E) placed on my customized board.
It is expected to: "The Virtual COM project is enumerated as a COM port, which the users can open using terminal tools, such as TeraTerm. The demo echoes back any character it receives".
I followed the user manual to connect the USB:
and the USB works fine. i.e- PC detects a COM port when I plug the USB to the PC.
But when I try to communicate trough teraTerm nothing happens so I doubt the communication is working. What am I doing wrong? Is this a windows problem?
All the best,
Filipe Costa
标记 (2)
2,093 次查看
filipecostapica
Hi jeremyzhou‌,
I haven't found your attach. Can you please resend it?
Sure I can.
BLOCO_USB:
Filipe Costa
2,093 次查看
jeremyzhou
Hi  Filipe Costa,
The USB interface seems good, and please check the attached tool.
TIC
2,093 次查看
jeremyzhou
Hi  Filipe Costa,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
I've attached a tool which is able to observe the enumeration process of a new attached USB device, please use it to validate the USB CDC device enumerate successfully.
In further, I was wondering if you can share the schematic of the USB interface of your customized board for me to check.
TIC
