LPC4333JET100 Ethernet and I2S use simultaneously
145218
I am planning to use LPC4333JET100 series mcu in an audio application. I need to use I2S and RMII for ethernet connection. In the datasheet some of the I2S and ethernet ports share the same pins. Is is possible to use both communication interface at the same time?
Thanks for any help.
Best
No, at one time, pins only can used as one function.
Alice
