LPC4088FET180 I2C1 pins - input impedance and current sinking when micro not powered
longboard
I am using an LPC4088FET180 micro on a single board computer (SBC) design. This board also incorporates an RTC chip. This chip uses a 3.0V coin cell for backup power when power is removed to the SBC. The I2C clock and data lines are pulled high through external 4.75k Ohm resistors.
I am trying to determine if there is a spec for the LPC4088FET180's I2C1 clock and data pins input impedance or ability to sink current, when power is removed from our single board computer (Vdd=0V). I think these pins should be high-Z when the LPC4088FET180 is not powered. I believe there are pull-up and/or pull-down resistors that can be present on the clock and data pins. So, I am not sure what the state of these pull-up or pull-down resistors would be on the I2C1 pins, when power is not applied to the micro (Vdd=0V). The information I can found in the datasheet related to the pull-ups or pull-downs, seems to be specific to Vdd being 3.3V. However, I am interested in knowing what the pull-up or pull-down values and states are when Vdd is 0V. I appreciate any help or information possible on this topic.
Harry_Zhang
Hi @longboard
I have checked the LPC408x/7x data sheet.
the LPC408x/7x family datasheet says the I²C pins are true open-drain and “when power is switched off, this pin connected to the I²C-bus is floating and does not disturb the I²C lines.” In other words, the pin driver itself goes high-Z when VDD = 0 V.
Harry
longboard
Hi Harry,
Thank you very much for pointing me to that information in the LPC408x/7x datasheet regarding the I2C bus pins state when Vdd=0V. I am glad to learn that the inputs are high-Z when Vdd=0V.
cheers,
Sean
%3CLINGO-SUB%20id%3D%22lingo-sub-2201068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC4088FET180%20I2C1%20pins%20-%20input%20impedance%20and%20current%20sinking%20when%20micro%20not%20powered%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20using%20an%20LPC4088FET180%20micro%20on%20a%20single%20board%20computer%20(SBC)%20design.%20This%20board%20also%20incorporates%20an%20RTC%20chip.%20This%20chip%20uses%20a%203.0V%20coin%20cell%20for%20backup%20power%20when%20power%20is%20removed%20to%20the%20SBC.%20The%20I2C%20clock%20and%20data%20lines%20are%20pulled%20high%20through%20external%204.75k%20Ohm%20resistors.%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20determine%20if%20there%20is%20a%20spec%20for%20the%20LPC4088FET180's%20I2C1%20clock%20and%20data%20pins%20input%20impedance%20or%20ability%20to%20sink%20current%2C%20when%20power%20is%20removed%20from%20our%20single%20board%20computer%20(Vdd%3D0V).%20I%20think%20these%20pins%20should%20be%20high-Z%20when%20the%20LPC4088FET180%20is%20not%20powered.%20I%20believe%20there%20are%20pull-up%20and%2For%20pull-down%20resistors%20that%20can%20be%20present%20on%20the%20clock%20and%20data%20pins.%20So%2C%20I%20am%20not%20sure%20what%20the%20state%20of%20these%20pull-up%20or%20pull-down%20resistors%20would%20be%20on%20the%20I2C1%20pins%2C%20when%20power%20is%20not%20applied%20to%20the%20micro%20(Vdd%3D0V).%20The%20information%20I%20can%20found%20in%20the%20datasheet%20related%20to%20the%20pull-ups%20or%20pull-downs%2C%20seems%20to%20be%20specific%20to%20Vdd%20being%203.3V.%20However%2C%20I%20am%20interested%20in%20knowing%20what%20the%20pull-up%20or%20pull-down%20values%20and%20states%20are%20when%20Vdd%20is%200V.%20I%20appreciate%20any%20help%20or%20information%20possible%20on%20this%20topic.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2201068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC40xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC4088FET180%20I2C1%20pins%20-%20input%20impedance%20and%20current%20sinking%20when%20micro%20not%20powered%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Harry%2C%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20pointing%20me%20to%20that%20information%20in%20the%20LPC408x%2F7x%20datasheet%20regarding%20the%20I2C%20bus%20pins%20state%20when%20Vdd%3D0V.%20I%20am%20glad%20to%20learn%20that%20the%20inputs%20are%20high-Z%20when%20Vdd%3D0V.%3C%2FP%3E%3CP%3Echeers%2C%3C%2FP%3E%3CP%3ESean%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC4088FET180%20I2C1%20pins%20-%20input%20impedance%20and%20current%20sinking%20when%20micro%20not%20powered%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256666%22%20target%3D%22_blank%22%3E%40longboard%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20have%20checked%20the%26nbsp%3BLPC408x%2F7x%20data%20sheet.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1762760385826.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1762760385826.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364642i32DFAD82C622628F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1762760385826.png%22%20alt%3D%22Harry_Zhang_0-1762760385826.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Ethe%20LPC408x%2F7x%20family%20datasheet%20says%20the%20I%C2%B2C%20pins%20are%20true%20open-drain%20and%20%E2%80%9Cwhen%20power%20is%20switched%20off%2C%20this%20pin%20connected%20to%20the%20I%C2%B2C-bus%20is%20floating%20and%20does%20not%20disturb%20the%20I%C2%B2C%20lines.%E2%80%9D%20In%20other%20words%2C%20the%20pin%20driver%20itself%20goes%20high-Z%20when%20VDD%20%3D%200%20V.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E
