LPC4088FET180 I2C1 pins - input impedance and current sinking when micro not powered
1,173件の閲覧回数
longboard
I am using an LPC4088FET180 micro on a single board computer (SBC) design. This board also incorporates an RTC chip. This chip uses a 3.0V coin cell for backup power when power is removed to the SBC. The I2C clock and data lines are pulled high through external 4.75k Ohm resistors.
I am trying to determine if there is a spec for the LPC4088FET180's I2C1 clock and data pins input impedance or ability to sink current, when power is removed from our single board computer (Vdd=0V). I think these pins should be high-Z when the LPC4088FET180 is not powered. I believe there are pull-up and/or pull-down resistors that can be present on the clock and data pins. So, I am not sure what the state of these pull-up or pull-down resistors would be on the I2C1 pins, when power is not applied to the micro (Vdd=0V). The information I can found in the datasheet related to the pull-ups or pull-downs, seems to be specific to Vdd being 3.3V. However, I am interested in knowing what the pull-up or pull-down values and states are when Vdd is 0V. I appreciate any help or information possible on this topic.
1,105件の閲覧回数
Harry_Zhang
Hi @longboard
I have checked the LPC408x/7x data sheet.
the LPC408x/7x family datasheet says the I²C pins are true open-drain and “when power is switched off, this pin connected to the I²C-bus is floating and does not disturb the I²C lines.” In other words, the pin driver itself goes high-Z when VDD = 0 V.
Harry
1,078件の閲覧回数
longboard
Hi Harry,
Thank you very much for pointing me to that information in the LPC408x/7x datasheet regarding the I2C bus pins state when Vdd=0V. I am glad to learn that the inputs are high-Z when Vdd=0V.
cheers,
Sean
%3CLINGO-SUB%20id%3D%22lingo-sub-2201068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC4088FET180%20I2C1%E3%83%94%E3%83%B3%20-%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E3%81%8D%E3%81%AE%E5%85%A5%E5%8A%9B%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%E3%81%A8%E9%9B%BB%E6%B5%81%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%20(SBC)%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A7%20LPC4088FET180%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%20RTC%20%E3%83%81%E3%83%83%E3%83%97%E3%82%82%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E3%80%81SBC%20%E3%81%B8%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E5%88%87%E6%96%AD%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E9%9B%BB%E6%BA%90%E3%81%A8%E3%81%97%E3%81%A6%203.0V%20%E3%82%B3%E3%82%A4%E3%83%B3%E5%9E%8B%E9%9B%BB%E6%B1%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82I2C%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%80%81%E5%A4%96%E9%83%A8%E3%81%AE%204.75k%20%E3%82%AA%E3%83%BC%E3%83%A0%E3%81%AE%E6%8A%B5%E6%8A%97%E5%99%A8%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%83%8F%E3%82%A4%E3%81%AB%E5%BC%95%E3%81%8D%E4%B8%8A%E3%81%92%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%8B%E3%82%89%E9%9B%BB%E6%BA%90%E3%81%8C%E9%99%A4%E5%8E%BB%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%20(Vdd%3D0V)%E3%80%81LPC4088FET180%20%E3%81%AE%20I2C1%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%BC%E3%82%BF%E3%83%94%E3%83%B3%E3%81%AE%E5%85%A5%E5%8A%9B%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%E3%81%BE%E3%81%9F%E3%81%AF%E9%9B%BB%E6%B5%81%E3%82%92%E3%82%B7%E3%83%B3%E3%82%AF%E3%81%99%E3%82%8B%E8%83%BD%E5%8A%9B%E3%81%AE%E4%BB%95%E6%A7%98%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82LPC4088FET180%20%E3%81%AB%E9%9B%BB%E6%BA%90%E3%81%8C%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E3%83%8F%E3%82%A4%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%94%E3%83%B3%E3%81%A8%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%94%E3%83%B3%E3%81%AB%E3%81%AF%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E6%8A%B5%E6%8A%97%E3%82%84%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%8A%B5%E6%8A%97%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%81%AB%E9%9B%BB%E6%BA%90%E3%81%8C%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E3%81%8D%20(Vdd%20%3D%200V)%E3%80%81I2C1%20%E3%83%94%E3%83%B3%E4%B8%8A%E3%81%AE%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%8A%B5%E6%8A%97%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8B%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%81%AF%E3%80%81Vdd%20%E3%81%8C%203.3V%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E7%89%B9%E6%9C%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81Vdd%20%E3%81%8C%200V%20%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%AE%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%AE%E5%80%A4%E3%81%A8%E7%8A%B6%E6%85%8B%E3%81%8C%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%80%81%E3%81%A7%E3%81%8D%E3%82%8B%E9%99%90%E3%82%8A%E3%81%AE%E3%81%94%E5%8A%A9%E5%8A%9B%E3%82%84%E6%83%85%E5%A0%B1%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2201068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC40xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC4088FET180%20I2C1%20pins%20-%20input%20impedance%20and%20current%20sinking%20when%20micro%20not%20powered%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%AA%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3EVdd%3D0V%20%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%AE%20I2C%20%E3%83%90%E3%82%B9%20%E3%83%94%E3%83%B3%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%20LPC408x%2F7x%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Vdd%3D0V%20%E3%81%AE%E3%81%A8%E3%81%8D%E5%85%A5%E5%8A%9B%E3%81%8C%E3%83%8F%E3%82%A4%20Z%20%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%86%E3%82%8C%E3%81%97%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC4088FET180%20I2C1%20pins%20-%20input%20impedance%20and%20current%20sinking%20when%20micro%20not%20powered%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256666%22%20target%3D%22_blank%22%3E%40longboard%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ELPC408x%2F7x%20%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1762760385826.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1762760385826.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364642i32DFAD82C622628F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1762760385826.png%22%20alt%3D%22Harry_Zhang_0-1762760385826.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1762760385826.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ELPC408x%2F7x%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81I%C2%B2C%20%E3%83%94%E3%83%B3%E3%81%AF%E7%9C%9F%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%20%E3%83%89%E3%83%AC%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%80%8C%E9%9B%BB%E6%BA%90%E3%81%8C%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81I%C2%B2C%20%E3%83%90%E3%82%B9%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E3%83%95%E3%83%AD%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81I%C2%B2C%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81VDD%20%3D%200%20V%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%94%E3%83%B3%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E8%87%AA%E4%BD%93%E3%81%AF%E3%83%8F%E3%82%A4%20Z%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
