LPC2468 demo boards
LPC2468 demo boards
lpcware
Content originally posted in LPCWare by dodge55 on Tue Sep 23 14:58:46 MST 2014
Does anyone carry LPC2468 demo boards any more?  Some say they are obsolete.  Is this a controller that should not be used for new designs?  I don't see any indication that this chip is reaching end of life.  Thanks.
Sutton
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Sep 24 00:05:13 MST 2014
The LPC2468 is certainly not yet obsolete (see http://www.nxp.com/techzones/microcontrollers-techzone/longevity.html) but certainly for new designs I would recommend that you consider a more modern MCU based on Cortex-M3 or M4 (LPC17xx, LPC18xx, LPC40xx or LPC43xx) rather than an older ARM7TDMI based part.
http://www.nxp.com/products/microcontrollers/cortex_m3/
http://www.nxp.com/products/microcontrollers/cortex_m4/
This will give you lots of advantages including ease of use and debugability. There is lots of information around comparing Cortex-M to ARM7, for example:
http://edn.com/design/systems-design/4314012/Choosing-between-an-ARM7-and-a-Cortex-M3-processor
http://www.arm.com/files/pdf/cortex-m3_programming_for_arm7_developers.pdf
But lots of people make LPC2468 based boards, so I don't see that you should have problems tracking one down. For example:
http://www.embeddedartists.com/products/kits/lpc2468_kit.php
http://www.keil.com/mcb2460/
https://www.olimex.com/Products/ARM/NXP/LPC-E2468/
LPCXpresso Support
