LPC2368 erase
LPC2368 erase
1,511件の閲覧回数
lpcware
Content originally posted in LPCWare by frank40 on Wed Dec 03 10:26:02 MST 2014
Hello
How erase LPC2368 cip with CRP3 enabled when no have communications via ISP and JTAG ?
Thank for your help.
Frank
2 返答(返信)
1,464件の閲覧回数
lpcware
Content originally posted in LPCWare by frank40 on Fri Dec 19 16:12:55 MST 2014
Thanks for reply.
1,464件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Dec 03 10:39:00 MST 2014
Unless you have built a secondary bootloader, you cannot. From the docs:
Quote:
Be aware that there is no built-in recovery for designs once CRP Level 3 is enabled
EDIT: But you may want to read this Application Note:
http://www.nxp.com/documents/application_note/AN10759.pdf
