LPC2194 microcontroller replacement
Unai_garcia
Hi everyone,
I am looking forward to start a new embedded system proyect and I was thinking about LPC microcontrollers.
I just saw that the LPC2194 microcontroller is not recommended for new designs anymore but I didn't find any suggestion on which microcontroller to use instead. I would need something with similar features of Flash/RAM size, CPU frequency and peripherals.
If anyone could suggest some options of microcontrollers to replace LPC2194, I would be really grateful.
Thanks in advance.
Labels (2)
vicentegomez
There is not direct replacement for the LPC2000 family devices (ARM A7 ) the new devices use ARM Cortex M. Depending you final application you can check the LPC546xx family (ARM M4)
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/general-purpose-mc...
Or also check the LPC55 family
Please let me know if you need more information or if you have more questions
vicentegomez
Unai_garcia
Great, I will check those and see if they meet my requirements.
Thank you very much for the reply!
Kind regards.
