LPC18xx external programmer
Content originally posted in LPCWare by leojose on Tue Feb 25 00:42:09 MST 2014
I would like to flash program my LPC1833-LQFP144 device before mounting it on my PCB. Are there any programmers available for the same?
Content originally posted in LPCWare by MarcVonWindscooting on Sun Mar 16 16:25:10 MST 2014
Even if flashing before soldering was possible, you don't want to 'age' your flash image by applying such elevated temperatures. I'm pretty sure, data retention is reduced.
Content originally posted in LPCWare by embd02161991 on Thu Feb 27 22:39:01 MST 2014
You can use Flash Magic tool for programming your chip. Other IDE's include Keil , LPCXpresso and IAR workbench.
NXP Technical Support
