LPC1837 locked up after bad clock config
lpcware
Content originally posted in LPCWare by mplu on Tue Dec 22 05:13:20 MST 2015
My LPC1837 locked up after a bad clock config. The "r" and "h" command using jlink.exe is not working. I'm using IAR EWArm 6.50.3.
lpcware
Content originally posted in LPCWare by vtw.433e on Tue Dec 22 08:58:47 MST 2015
You're screwed then. You can only recover by physically booting into ISP
lpcware
Content originally posted in LPCWare by mplu on Tue Dec 22 08:24:22 MST 2015
I forgot one thing : I'm working on a board with no access to isp pin. =\
lpcware
Content originally posted in LPCWare by vtw.433e on Tue Dec 22 07:11:33 MST 2015
Boot into ISP mode, as described in the User Manual - or search this forum for details
