LPC1788 USB Interfacing
Content originally posted in LPCWare by jay123 on Mon May 19 23:19:02 MST 2014
Microcontroller Use: LPC1788
presently i'm downloading my application through RS232 serial communication, but downloading time increase with increase in application size .
so  now i want to implement USB for fast download.
basic software requirement
a) USB initialize function
b) read function
c) write function
i have computer application for application download, in that application i select COM port, and other required setting after completion of setting  i hit download button and its start downloading, similarly i want same for USB, when i connect USB cable to computer it should generate USB device say USB0 and USB0 use for downloading.
please help me to implement USB Device
Content originally posted in LPCWare by embd02161991 on Fri May 23 12:38:52 MST 2014
You can try using the usb mass storage class example on lpcware.com and develop to implement your application.
http://www.lpcware.com/content/nxpfile/lpcopen-software-development-platform-lpc17xx-packages
NXP Technical Support
