LPC1788 OEM Board revA - External RAM connection
lpcware
Content originally posted in LPCWare by sipel_tp on Fri May 31 04:18:23 MST 2013
Perhaps this is a silly question but I cannot figure out if the IS42S32800B ram data pins from 0 to 15 are connected to the EMC bus of the LPC1788. The schematics is not enough clear for me. Thank you for your answer.
lpcware
Content originally posted in LPCWare by sipel_tp on Fri May 31 06:34:03 MST 2013
Problem solved. They're connected
