LPC1768 Dm9161 schematic
13,884件の閲覧回数
lpcware
Content originally posted in LPCWare by LeonCorleone on Fri Jan 08 02:51:28 MST 2016
Hello to all. I want to create a web sever with easy web example by LPC1768 and Dm9161 as PHY. Does somebody has the right schematic for it.? Very thank you.
6 返答(返信)
13,694件の閲覧回数
lpcware
Content originally posted in LPCWare by R2D2 on Mon Jan 11 03:51:36 MST 2016
Or:
http://www.digikey.de/product-detail/en/RC0603JR-070RL/311-0.0GRTR-ND/726675?cur=EUR&lang=en
13,694件の閲覧回数
lpcware
Content originally posted in LPCWare by serge on Mon Jan 11 02:55:42 MST 2016
0R is NOT an inductor but just a wire link
13,694件の閲覧回数
lpcware
Content originally posted in LPCWare by LeonCorleone on Sun Jan 10 00:38:45 MST 2016
How about the 0R inductor.
If I ignoring it , does it make me problem?
13,694件の閲覧回数
lpcware
Content originally posted in LPCWare by MikeSimmonds on Sat Jan 09 22:15:22 MST 2016
'0R' is zero (0) ohms. Just a wire link.
Use a 25 MHz crystal for RMII mode
or a 50 Mhz crystal for MII mode (not recommended).
YOU can Google for data sheets and application notes.
Cheers, Mike.
13,694件の閲覧回数
lpcware
Content originally posted in LPCWare by LeonCorleone on Fri Jan 08 23:16:48 MST 2016
what is the difference between lan8120 with lan8720a.
Actually I have a circuit like below belong to Mini-DK2 board.
Two questions:
1- what does it mean "0R" here?
2-What exactly kind of crystal I should use?
Thanks.
13,694件の閲覧回数
lpcware
Content originally posted in LPCWare by MikeSimmonds on Fri Jan 08 03:12:40 MST 2016
A quick Google gave me this Don't you know how
to Google!
See the AN+Schematics down the page.
I did not open them -- that's YOUR job.
But if this a new design, why not go with the already LCPOpen supported LAN8720?
Cheers, Mike.
