LPC1764
LPC1764
5,108件の閲覧回数
djtilava
Is it possible to merge Two Seperate RAM region in LPC1764 using Linker Script? If Yes then Let me guide how to do that? Using LPCXpresso IDE it is not possible.
タグ(2)
2 返答(返信)
4,860件の閲覧回数
Carlos_Mendoza
Hi Divyesh,
Since the RAM regions are not contiguous you cannot merge them into one single region. I would recommend you to take a look to the following document that explains how to place data items into specific RAM blocks:
Placing data into different RAM blocks
Hope it helps!
Carlos Mendoza
Technical Support Engineer
4,856件の閲覧回数
djtilava
Will you be plese help me in developing Serial to Ethernet and vice-versa converter using LPC1764+ TLK105 .I have made it but it works only for some time and some web pages are not load in web browser.
i have take reference of "Serial to Ethernet Converter for TM4C129x Microcontrollers Using RTOS"  but i am not using RTOS.
@Carlos_Mendoza @jeremyzhou
lpcware‌ Carlos_Mendoza @Kerry Zhou
