LPC1756 control main PLL
lpcware
Content originally posted in LPCWare by Linas on Thu Feb 07 03:09:21 MST 2013
Is is allowed and safe to dynamically change PLL clock in the LPC1756? Let's say during the program flow I
will reduce from 80 MHz to 30 MHz. Is it safe? I know that I will need to reinitialize all peripherals in this case.
Best,
Linas
lpcware
Content originally posted in LPCWare by Linas on Fri Feb 08 07:47:51 MST 2013
I only ask for some help. Maybe some one had the same task. I don't know how replies are related to this question :-).
Best,
Linas
lpcware
Content originally posted in LPCWare by mburton on Fri Feb 08 06:10:57 MST 2013
Yes, my thought is that if you don't acknowledge replies to your questions, people are less inclined to respond.
lpcware
Content originally posted in LPCWare by Linas on Fri Feb 08 04:44:50 MST 2013
Maybe there are some thoughts?
Thanks!
Linas
