LPC1549, how to self erase program in flash?
1,984件の閲覧回数
richardpayne
Fresh Out Contributor
I have a test firmware installed.
After test I wish to delete the firmware by itself or just erase the 1st part of code which make it unbootable.
I have read the datasheet and wondered what the correct approach to this.
Can the test firmware run on IAP mode?
Can you demostrate step to implement this.
R.
ラベル(2)
2 返答(返信)
1,727件の閲覧回数
richardpayne
Thanks, it was success!
R.
1,727件の閲覧回数
jeremyzhou
Hi richard payne,
the opportunity to serve you.
To provide the fastest possible support I want to point you to a
similar question which has been answered on our NXP community.
to view the details.
TIC
