LPC1549, how to self erase program in flash?
1,940 次查看
richardpayne
Fresh Out Contributor
I have a test firmware installed.
After test I wish to delete the firmware by itself or just erase the 1st part of code which make it unbootable.
I have read the datasheet and wondered what the correct approach to this.
Can the test firmware run on IAP mode?
Can you demostrate step to implement this.
R.
标签 (2)
1,683 次查看
richardpayne
Thanks, it was success!
R.
1,683 次查看
jeremyzhou
Hi richard payne,
the opportunity to serve you.
To provide the fastest possible support I want to point you to a
similar question which has been answered on our NXP community.
to view the details.
TIC
