LPC1343 DALI to USB python-dali integration
chiarafornoni
I'm new to microcontroller world, I've looked at  LPC1343 DALI to USB master demo board and asked if the library  python-dali can communicate with this board, the good guys said me:
It looks like it'll work for 16-bit forward frames and 8-bit reverse frames with the supplied firmware. You could probably extend the firmware to deal with transmission and reception of 24-bit frames.
Supported hardware list · Issue #35 · sde1000/python-dali · GitHub
I  kindly ask you if the conversion of the software is a big deal, can you please say me what steps are needed to make this edit.
Thanks BR
