LPC11xx i2c slave example
3,174件の閲覧回数
pyot
I'm looking for sample code of LPC11xx i2c slave.
I want to send back bytes to the master from slave.
Please tell me direction of such a example codes.
タグ(1)
2 返答(返信)
2,448件の閲覧回数
soledad
You can use LPCOpen software for LPC11xx. LPCOpen Software for LPC11XX|NXP
LPCOpen contains an I2C example that you can use as reference. This example shows how to use I2C as master or slave and communicate between Master and Slave with polling/interrupt mode. (Interrupt mode is default).
I hope this helps,
Soledad
2,448件の閲覧回数
pyot
Hi Soledad,
Thank you for your direction.
I will try use it.
Best  Regards,
py ot
