LPC1125 secondary bootloader issue
1,398件の閲覧回数
Content originally posted in LPCWare by CH Wu on Fri Sep 25 13:33:32 MST 2015
I have an issue of jumping to application code from bootloader code.
I have experience with LPC111x series regarding the secondary bootloader.
Somehow I can't duplicate the same result in LPC112x.
As I known, the LPC111x and LPC112x are the same expect the NVIC table.
I have tried many ways to solve my problem but still be blocked with this issue.
I attached my test code. Please give me an advice. Thanks.
Original Attachment has been moved to: Bootloader_test.zip
1,311件の閲覧回数
Content originally posted in LPCWare by CH Wu on Mon Sep 28 06:28:26 MST 2015
Sorry to get you confused, my bootloader and application code are at the the periph_blinky project.
Enclosed the .c files for your reference.
1,311件の閲覧回数
Content originally posted in LPCWare by R2D2 on Fri Sep 25 14:38:21 MST 2015
Quote: CH Wu
...I have an issue of jumping to application code from bootloader code.
And this 'jumping to application' is where in your 35 MB zip  :quest:
