LPC1114 pull up/down resistors value?
1,656 次查看
lpcware
Content originally posted in LPCWare by sipel_tp on Fri Aug 03 04:36:31 MST 2012
Does somebody know the LPC1114 pull up/down resistors value? I can't find this information anywhere. Thanks again!
标签 (1)
3 回复数
1,588 次查看
lpcware
Content originally posted in LPCWare by nxpsupport on Fri Nov 09 16:16:06 MST 2012
The pull-up and pull-downs are not actual resistors. They are transistors configured as a current source. These are "weak" current sources. For simplicity we call it a resistors.
1,588 次查看
lpcware
Content originally posted in LPCWare by SteveMerrick on Mon Aug 06 06:41:33 MST 2012
I think the pull-up is an active pull-up, not a passive resistor. There's no simple value (in ohms) for an active pull-up.
1,588 次查看
lpcware
Content originally posted in LPCWare by tha on Fri Aug 03 18:04:19 MST 2012
The pull-up/down is listed as a IV graph in the datasheet.  Base on the operating condition, you would get different values.
