LPC-link 2 is stopped detected by system
3,603 次查看
priyadarshinisi
I am using LPC-Link 2 for debugging my LPC1769 board. It was working fine till now, but suddenly it stopped working.
Here I meant by Stopped working is, now my LPC-link 2 is not detected by my system. I tried a different system, changing com ports and various cable too but still, LPC-link 2 device is not detected by any of the systems. LED1(bootLed) is blinking whenever I connect LPC-Link 2 with USBcable.
Anyone can help in finding what is basically the problem with my LPC-link 2 and how I can fix it.
lpcware‌lpcware-support‌lpcxpresso_support‌
#lpclink2‌ #nxp lpc1769‌
标记 (2)
5 回复数
3,369 次查看
lpcxpresso_supp
So are you trying to use your LPC-Link2 with LPCXpresso IDE and letting LPCXpresso IDE softload the probe firmware? Or have you preprogrammed the Link2's flash with probe firmware using LPCScrypt?
https://community.nxp.com/message/630661
And have you actually tried any of the troubleshooting suggestions at all in the FAQ we previously pointed you at?
LPCXpresso Support
3,369 次查看
priyadarshinisi
I am using LPC-Link2 with LPCXpresso IDE and letting LPCXpresso IDE
softload the probe firmware.
A few days ago LPC Link-2 was performing well.
I was able to see "LPC Device" in my device and drivers.
Suddenly, Out of the box. It stopped detecting by my system (even I tried
other systems too.)
3,369 次查看
lpcxpresso_supp
Check out : https://community.nxp.com/message/630577
If you still have problems, give details of what you see in see at each stage of the manual boot process in Devices and Printers (assuming you are using Windows).
LPCXpresso Support
3,369 次查看
priyadarshinisi
My LPC-Link 2 is not visible at  Devices and Printers.
2,047 次查看
ravicha
did u get the solution i face the same problem i am try to connect mcxc243 with link 2 before it connect but now it is not able to connect so please can u help me with your solution , Thanks
