LPC internal BGA routing
2,026 次查看
koenvanderaa
I'm working on a new PCB with the LPC1830FET100 a BGA prackage. But is there a tool to easy route the internal pheripherials I/O to the desigerd pin? It would make my life a lot easier!
Koen Van der Aa
标签 (2)
标记 (3)
1,905 次查看
koenvanderaa
Thanks a lot Carlos Mendoza!
Just what i need.
Koen Van der Aa
1,905 次查看
Carlos_Mendoza
Hi Koen Van der Aa,
I would recommend you to use the LPC18xx Pin Mux tool:
LPC18xx Pin Mux tool | www.LPCware.com
Hope it helps!
Carlos Mendoza
Technical Support Engineer
