LPC Microcontroller
LPC Microcontroller
JLABB
Hello I have worked on the LPC55S06JHI48 board and I am trying to figure out if the board supports the arm_math.h header file.
frank_m
Senior Contributor III
The arm_math.h file is a generic CMSIS header supplied by ARM.
The CMSIS package supplied with SDKs for your MCU should support the M33 MCUs. But you can check the header section of the file.
