LPC 1758 debug with MCUXpresso IDE
rasodm
I'm using DEVELO dLAN Green PHY eval board II which has LPC 1758. I'm using MCUXpresso IDE. In the data sheet of dLAN Green PHY has mentioned that it is compatible with UART and JTAG. But in MCUXpresso IDE it does not detect the FTDI UART or XDS 110 JTAG. How should I debug with LPC 1758 using MCUXpresso IDE?
GitHub
GitHub - devolo/dlan-greenphy-sdk: The devolo dLAN Green PHY module is ideal for installation in all...
Datasheet
https://www.i2se.com/wp-content/uploads/2017/10/devolo_dlan_green_phy_module_data_sheet_1216.pdf
#lpc1758‌ #using the mcuxpresso ide‌ #mcuxpresso linker‌ #jtag debug‌ uart‌
Thanks.
