LPC 11U14 with CLEV 663B blueboard 3.0
1,059件の閲覧回数
lpcware
Content originally posted in LPCWare by moonchill on Fri Oct 31 01:36:49 MST 2014
Hello all,
I am new to these 2 products. I  have followed the user guide manual to set up IDE and it works fine with my MCU board 11u14.
Now i am trying to make it work with CLEV663B blueboard. However, when i read the user guide manual of blueboard, i notice that they are using LPC 1769 and 1227. I am not sure whether my 11U14 is compatible with these 2 boards.  What can i do to run this example code on my own MCU board.
Thank you
1,006件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri Oct 31 02:33:09 MST 2014
I've checked with the appropriate team and I'm afraid that the CLEV663B and its examples are only suitable for use with LPCXpresso1769 (OM13000) and LPCXpresso1227  (OM13008) boards…
http://www.lpcware.com/LPCXpressoV1Boards
You should be able to purchase one of these from one of your favourite distributors.
For support on using the CLEV663B board, I would suggest using the email support link on the left hand side of this page:
http://www.nxp.com/demoboard/CLEV663B.html#support
LPCXpresso Support
