Issues with testing alexa and LPC 54018 board
3,002件の閲覧回数
tanmayparashar9
I am working with Alexa, AWS and LPC 54018 module. I have followed the steps as mentioned in the lab document attached here. I have set everything up as mentioned.
I am using Alexa simulator to test the on board LED. Whenever I say " ALEXA ask my home to turn on/off the LED" I get a response which says the LED if OFF in both the cases.
A message like this pops up- " Error retrieving device rendering- The object provided is not a valid template"
I am not understanding where I am going wrong. I have added a few attachments here for your reference.
If you need login credentials at the AWS-Lambda/IOT and Alexa Skills side, I can provide you with those to check what the issue is.
Please help me out.
Thank You!
Warm Regards,
Tanmay
タグ(1)
2,877件の閲覧回数
Sabina_Bruce
Hi Tanmay,
Thank you for the information you have provided this will be helpful in finding the root causes. In order to have the information in one place we will continue in the original thread.
https://community.nxp.com/message/1136435?commentID=1136435&et=watches.email.thread#comment-1136435
Thank you,
Sabina
