Is it possible to set SPI to be secure in the LPC55S69-EVK board?
2,917 次查看
mat1024
I am new to Trustzone-M so my question can be awkward and stupid, but I am curious if I can set SPI on the board as secure. What I mean by 'secure' is that I want only a trusted application can access that SPI.
I plan to use a WiFi expansion board(WiFi 10 click) with the main board, and I guess the expansion board can be connected through SPI. I want to lock the WiFi module only can be used by the trusted application, but I don't know how to start and even I am not sure whether or not it is feasible to do.
Or, can I preempt sending a packet even though the expansion board is used by other processes? I want to prioritize my application to any other programs to use the WiFi module.
Also, I am trying to find the document with register maps for the LPC55S69 board, but I can't easily find it.
Any answers or guidance would be highly appreciated. Thanks a lot!
2,893 次查看
Hello mat1024,
1) There is  Trustzone demo under SDK , you can first have a look, download from:
https://mcuxpresso.nxp.com/en/select
2) There is a trustzone hands-on with lpc55s69, you can also have a look at, I attach it for you.
3)About  register maps for the LPC55S69 board, how about the User Manual:
https://cache.nxp.com.cn/secured/assets/documents/en/user-guide/UM11126.pdf?__gda__=1660040005_517e0...
Alice
2,885 次查看
mat1024
Hi Alice,
Thanks for your reply. I already downloaded the TZ demo in SDK, and tried to understand whether it is feasible to use TZ for the secure SPI by observing the source code.
I am looking into the user manual document, but still don't clearly know if I can lock SPI.
If you can introduce someone who is an expert on TZ-M, it would be greatly appreciated!
Thanks!
Best,
Youngil Kim
2,872 次查看
Hello mat1024,
You can configure SPI in security area, refer to:
https://community.nxp.com/t5/LPC-Microcontrollers-Knowledge/Operate-peripherals-under-TrustZone/ta-p...
Alice
