Is FXLS60230AES an upgrade to FXLS60220AES?
tonugh
Can FXLS60230AES replace FXLS60220AESR2?
The only difference is
Alice
tonugh
Thank you for your very detailed reply, I would like to know, 1. Can FXLS60230AESR2 be used instead of FXLS60220AESR2? If FXLS60230AESR2 can be used instead of XLS60220AESR2, we plan to use this FXLS60230AESR2.
If the rang difference doesn't affect your project, yes, it can replace.
tonugh
We need your help. Our engineer would like to see the detailed technical data of FXLS60230AESR2, can you send me a copy? thank you very much!
Please create a private ticket from here: https://support.nxp.com/s/
There will be related support help you.
Alice
tonugh
Hi!
We want to see the detailed parameters of FXLS60230AESR2, can you send us a detailed technical information. So we can use this FXLS60230AESR2 product.
Materials or PDF documents, you can send to my email address [email protected].
