Interrupt process - what happens inside? Cortex M0+
2,098 次查看
jeanvaljean
Gentlemen,
Where can I find the most detailed description of the interrupt process in my Cortex M0 controller?
I'd like to know, for example, if I need to clear the pending IT request, if I need to save the PC to the stack and later load it back, and so on.
The concrete controller is: LPC11E68.
The user manual details only the NVIC registers - necessary info, but not enough.
I use LPCXPresso 8.1.4 and Win7. (if it is significant in this case
标签 (1)
1 回复
1,961 次查看
lpcxpresso_supp
ARM provide lots of information themselves on NVIC iinterrupt controller in their Cortex-M0+ (the CPU inside the LPC11E68) and Architecture v6-M documentation (at ARM Information Center ).
Joseph Yiu's book is also a good source (The Definitive Guide to ARM® Cortex®-M0 and Cortex-M0+ Processors, Joseph Yiu, eBook - Amazon.com ) but if use your favourite search engine and look for "cortex-m nvic' or similar, there is lots of information around on the internet - for example:
LPCXpresso Support
