Inquiry About USB Connectivity and Verification for LPC11C24F Microcontroller
736件の閲覧回数
Sumedha
Greetings,
I am Sumedha, and I am from Continental Automotive Singapore Pte Ltd.
I am presently working on a project with the LPC11C24F microcontroller. I managed to utilize a USB to UART cable and the respective pins 47 (TX), 46 (RX), and 41 (Ground) successfully. Is there a specific command or method to check if the USB connection has been successfully made?  Can you suggest a way to check if the USB connection has been properly set up? I have been facing a problem for the past week in confirming the connection status. Furthermore, I would be grateful for any suggestions on USB to UART cables that NXP would support for use with the LPC11C24F.One more issue that is encountered would be sometimes I encounter garbage values for certain Baud Rate but sometimes there is no garbage value detected. Secondly when i power up the board how many LED's are specifically turned on.
Thank you so much for backing me up. I am eagerly anticipating your prompt response.
Warm regards,
Sumedha Putta
Product Cybersecurity & Privacy Office
Automotive Technology 
Software and Central Technologies – Architecture & Software
Bill/Visitor Address:
Continental Building, 80 Boon Keng Road,
Singapore 339780  
Email :   [email protected]
Web   :   www.continental-automotive.com
0 返答(返信)
