IEC60730 library example projects
MLapaj
Where can example projects for IEC607030 library be found? A few months back they were available when building SDK in NXP dashboard, however they are nowhere to be found there right now.
I'm mainly interested in LPC804 example project at the moment.
Thanks in advance,
M. Lapaj
vicentegomez
Sorry in this case you need to use the sample of the LPC824 to migrate to the LPC80x
vicentegomez
grzegorzkonopko
@vicentegomez
I also looking examples for LPC804, it is missing in SDK builder, but indeed is available for LPC824MAX.
Please have a look attachment.
vicentegomez
Please use  the files in the next link
https://www.nxp.com/downloads/en/libraries/IEC60730B_CM0_4_0.zip
you need to add this library to your project
MLapaj
This link only provides the essential IEC60730 library (not a working project), whereas I am looking for an example project, which would illustrate an example use of the said library.
vicentegomez
MLapaj
After clicking in your link and then chosing LPCXpresso804 from "Example Projects" I am getting redirected to SDK builder and as I mentioned before IEC60730 example projects are no longer available there. I even downloaded the new SDK once again, and IEC60730 were not in the example projects.
Just to make sure you follow what I'm saying is, back in the days I could attach IEC60730 examples by checking it's box in SDK builder, but that library simply does not appear there anymore - please see the attached screenshot
Am I missing something? If so, could you please guide me step by step how exactly I can download IEC example projects?
