IAP flash memory Read and Write in LPC804
Sathiya_T
I am using IAP flash memory package in  LPC804 ,its worked in DEMO_IAP_FLASH_SECTOR (0-31) various sector.
It can be read and write a  data to given memory location, but in the same logics are not worked in flash memory of  29KB in LPC804.
only the IAP package is working good in less memory space for example 10KB or 12KB  of lpc804, otherwise it is  not read and write  any single data from  29KB or 30KB of flash memory .
Hello @Sathiya_T
Please share your project, I will help to check and test on my side, thanks.
Alice
Sathiya_T
I cant able to share the project,since I not having the access to sharing files. But our project having the size of 29KB (29KB of 32 KB).
Kindly update the solution
Hello @Sathiya_T
Without a project to reproduce your issue, it hardly to check the problem, you can create a private ticket with your project:
https://support.nxp.com/s/?language=en_US
Alice
