I need help.
I need help.
lpcware
Content originally posted in LPCWare by trsa.foto on Thu Oct 29 03:05:28 MST 2015
I'm currently an probetion  for an electronics system development company and they gave me LPC1788 and Topway LMT057DCDFWU-NBA  to work with.  I don`t have mentor or any kind of help. I don`t have any example.
I'm also very new to programming therefore it is rather hard for me to work with the device.  If someone could give me some kind of help, or some initalization code for LPC 1788 lcd controller, or some example ?
Any advice is welcomed.
Thank you very much.
Dejan
lpcware
Content originally posted in LPCWare by bavarian on Fri Oct 30 06:03:30 MST 2015
Two meaningful examples:
https://www.lpcware.com/content/nxpfile/emwin-industrial-example
https://www.lpcware.com/content/nxpfile/emwin-home-automation-example
The display needs to be adapted of course (the way the backlight is switched on etc.), it's not the one from Topway. Also the LPC1788 board you have might differ from the Embedded Artists board used in these two examples.
Our emWin site on LPCWare also contains code for the EA LPC1788 board.
Happy learning,
NXP Support Team.
