I ask you about usage of lpc_dfuutil.
1,601 次查看
hiromasashigema
How are you.
I have already used this community about 3 years ago concernibg to LPC1830.
I have used the libusb0 device driver from sourceforge for to communicate with LPC1830.
I want to change this driver to WinUSBNet or LibUsbDotNet for C#.
After the above change, is it necessay to give information to lpc_dfuutil.exe.
If you give me any comment, I am very happy.
Shiggy
标记 (1)
1,435 次查看
graygirling
You should be able to find information about dfu-util from the maintainers at dfu-util Homepage.
There may be small differences between that version of dfu-util and the one distributed with LPCXpresso IDE, which might be older.
Some information is also provided using the command
dfu-util --help
Sincerely
LPCXpresso IDE Support
