Huge power consumption on RTC ofLPCXpresso54S018M EVB.
jcxz
I use are LPCXpresso54S018M EVB. I need the RTC in the LPC54018 to work after the main power supply is removed. I initialized and enabled the RTC in my firmware. I powered the VBATT line (J10:11) with a coin cell battery CR2032. While the main power is present, the VBATT line consumption is == 0. It's Ok. However, after removing the main power supply, the VBATT line consumption increases up to ~41 uA! According to the datasheet, consumption should be less than 1 uA. Why? How can I achieve current consumption of 1 µA or less?
%3CLINGO-SUB%20id%3D%22lingo-sub-2415922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHuge%20power%20consumption%20on%20RTC%20ofLPCXpresso54S018M%20EVB.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20use%20are%20LPCXpresso54S018M%20EVB.%20I%20need%20the%20RTC%20in%20the%20LPC54018%20to%20work%20after%20the%20main%20power%20supply%20is%20removed.%20I%20initialized%20and%20enabled%20the%20RTC%20in%20my%20firmware.%20I%20powered%20the%20VBATT%20line%20(J10%3A11)%20with%20a%20coin%20cell%20battery%20CR2032.%20While%20the%20main%20power%20is%20present%2C%20the%20VBATT%20line%20consumption%20is%20%3D%3D%200.%20It's%20Ok.%20However%2C%20after%20removing%20the%20main%20power%20supply%2C%20the%20VBATT%20line%20consumption%20increases%20up%20to%20~41%20uA!%20According%20to%20the%20datasheet%2C%20consumption%20should%20be%20less%20than%201%20uA.%20Why%3F%20How%20can%20I%20achieve%20current%20consumption%20of%201%20%C2%B5A%20or%20less%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2415922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC54xxx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
